Window Leaks
Old Aug 10, 2015 | 10:49 AM
mudfuel06's Avatar
mudfuel06
Window Leaks
I have pulled the windows and replaced the seals with new butyl tape as well as caulking around the edges. I am still getting water inside the window on the bottom. Any ideas on where it could be coming from? I'm going to have to replace all the paneling that I just replaced about a year ago now.
Old Aug 10, 2015 | 04:23 PM
senix's Avatar
senix
can you pull the beauty ring off the inside and tell what is happening?
Seems to me if you have calked all around it then is should only leak if the seal on the glass itself was bad.
Old Aug 10, 2015 | 07:43 PM
mudfuel06's Avatar
mudfuel06
Senix, that's what I'm thinking. The water is coming and sitting on the beauty ring before going down the wall. I guess the next step is to pull the rubber trim on the outside of the window and try resealing. I have 3 of them doing it now.
Old Aug 10, 2015 | 08:29 PM
senix's Avatar
senix
Not going to be fun. I guess start at your worst window.
Old Aug 11, 2015 | 07:40 AM
RV_Tech's Avatar
RV_Tech
Pull the beauty ring first. If the window is leaking you can see it at the bottom on the hole the window sits in. Water can also leak from above the window and work is way down so it looks like the window is leaking.
Also make sure the weepers in the window frame are open so the water leaks out, not in.
Steve
Old Aug 11, 2015 | 01:36 PM
mudfuel06's Avatar
mudfuel06
Steve
Steve, I have made sure a couple of times that the weepeers are clear, that was my first thought. The water actually sits on top of the beauty ring for the window. On mine, there is about an inch and a half flat piece from the inside to the outside and the water is sitting on that. When I saw it, I was more concerend about getting towels on it to try and keep it from getting worse, but it apparently has been doing it for awhile now. I'll pull the trim and see what I can find.
Old Sep 8, 2015 | 08:46 AM
mudfuel06's Avatar
mudfuel06
Just an update. I pulled the outside trim off the window. Lo and behold, there are two sets of drainage holes. I cleaned those out, and knock on wood, it seems to have solved the problem. There was a lot of junk in the track, so I'm thinking it was causing the water to back up and go inside the window to the trailer. We had a hard rain here last night, and everything is dry. Fingers crossed!
Old Sep 8, 2015 | 11:12 AM
senix's Avatar
senix
Great news! Thanks for reporting back.
Old May 22, 2018 | 09:05 PM
HRTKD's Avatar
HRTKD
My window developed a leak recently and I'm not sure where the leak is coming from. I'm going to check the weep/drain holes first but it wouldn't surprise me to find that the seal around the window is the problem.
How do I know what width of butyl tape to use? Any specific brand/type of caulk to use? On a YouTube video I saw that they caulked the top and about half way down each side, but not the bottom.
brc777
1997 - 2003 F150
Jul 10, 2018 09:16 AM
69cj
All Things Towing
17
Feb 4, 2017 06:54 PM
mudfuel06
Aug 10, 2015 10:48 AM
johnw
1997 - 2003 F150
Apr 24, 2005 02:35 PM
homer4.2
1997 - 2003 F150
Feb 9, 2005 10:36 PM
