Stealth MSD box
Old Aug 8, 2015 | 09:59 PM
DaytonaTunnel's Avatar
DaytonaTunnel
Stealth MSD box
I wanted to "hide" my MSD box. Here it is, minus the wire loom. I drilled out the rivets, had the box blasted and coated in an aluminum color. I had to flip the battery and coil wire outputs so they came out where I needed them. I soldered all the factory plugs on, and will mount it in the stock ignition. I will have to change a wire close the dist from dist ground to coil ground. Should be easy to hide. Now it will plug in to the factory harness.
This is on my 79 Crew cab 4x4 project. if your interested in more pic's of the progress, they can be found here;
1979 4x4 Crewcab build - Old Ford Crew Cab Community
DaytonaTunnel
Aug 8, 2015 08:52 PM
crazyeddie
Aftermarket Products
Sep 2, 2010 09:50 PM
9d4
Oct 29, 2009 06:17 PM
superswamper
Jul 28, 2003 07:43 PM
79supercab4x4
May 29, 2001 12:16 PM
