Modular V10 (6.8l)
Vacuum Problem
Old Apr 14, 2009 | 03:52 PM
palmer8996's Avatar
palmer8996
Vacuum Problem
Ok guys need some help with 2004 f-250 6.8 4x4. When I step on the gas my air cuts out then blows defrost. I have checked all the vacuum lines found one that was off put it on and still have the problem. The dealership told me the "check valve" in the vacuum can was bad. Is their a check valve in the can or is it somewere else? Anyone know if I can get the check valve or can at NAPA. Thanks Palmer
Old Apr 15, 2009 | 01:37 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Not entirely sure, but I think there is a check valve inline somewhere in the vacuum lines.
Might be around the diameter of a quarter, and about 1/4" thick.
Old Apr 16, 2009 | 03:54 PM
bigdaddymedic2000's Avatar
bigdaddymedic2000
my 2001 EX had the same problem. mine was bad auto locking hubs on the front. i replaced them with warn manual hubs and capped off the vacuum lines. the problem was fixed. the old auto hubs were gummed up so bad that you could not turn them with BIG channel locks. and the auto locking hubs were a Ford only part and $325.00 each. warn manuals were $190.00.
Old Apr 16, 2009 | 08:47 PM
palmer8996's Avatar
palmer8996
I got a vacuum can with the check valve in it from NAPA. If thtat doesn't work am going to try something else. I checked my hubs the other day and both worked freely.
Old Apr 17, 2009 | 06:14 AM
bigdaddymedic2000
the guy that works on my EX had told me, there's also a seal around the auto hub that leaks vacuum. and there is a small vacuum control box on the fender wall that will sometimes go bad. my friend also had the vacuum can as a possible problem. it is/was annoying to have the air flow keep switching back and forth.
