Sponsored by: Real Truck
ESOF Issues
Old Aug 23, 2009 | 12:15 PM
onephinesuperduty's Avatar
onephinesuperduty
ESOF Issues
Hey everybody! Im trying to get my ESOF hubs back up and running. Its a 2001 5.4 liter. I had a leak, just fixed it, vacuum line was busted off down by hub. Still no lock in. If i turn the hubs by hand the 4x4 works fine. All lights on the dash work for 4x4 and LOW. I hear the clicking sound down in the transfer case. I plugged the line with my finger and dont feel any vacuum at all. Im assuming no vacuum is being generated. Is there a vacuum pump on the gassers, or is it run of intake manifold vacuum somehow? Does anybody have any ideas of what I need to test or replace to get the situation rectified? Thanks in advance!!
Old Aug 23, 2009 | 10:15 PM
onephinesuperduty
addendum: I checked all the fuses inside the truck and under the hood and all are good.
Old Aug 24, 2009 | 07:11 AM
12ozd's Avatar
12ozd
Check / follow / replace the vacuum lines form the hubs all the way back.
Old Aug 24, 2009 | 10:35 AM
EXv10's Avatar
EXv10
You would have to remove the hubs, clean, check seals, grease and replace before you could do anything. THEN, there is a lot of info on it in here if you do a search.
