Random questions!
Then remove the 5 screws first. Far left between the headlight/wiper *****, there are 2 screws, 1 between the *****, and 1 above it, going in straight up. Moving right there are 2 more screws. 1 in the middle, 1 far right, both pointing straight up. Section heater control there is 1 screw pointing straight up.
Heater controls are in behind the dash plastic, they stay where they are, but you will slide/squeeze the levers out of way to prevent them from hooking on the dash bezel.
To remove the wiper **** it has a release clip on its shaft that you can put pressure on with small flat tip screwdriver in the tiny slot, press and release and slide the **** off.
Radio may be behind or in front the dash bezel, depending on how previous owner (P.O.) installed it. If its factory or shaft style, pull the ***** off the radio and you will see shallow nuts on the shafts. Clean the shaft threads with elec cleaner and small brush, because the shafts will strip VERY easily, use a deep set socket on them. Once the nuts are removed, there should be a plastic or metal radio plate to remove. Behind that are 2 more screws holding dash bezel to a metal bracket. But not always…
Okay, under the 3 sections that you see the gauges in, under the middle one there is a plastic tab from the dash bezel that is tucked behind the metal part of the dash. You can see the metal cutout area for it, when the headlight ****/shaft is pulled out or removed all together you can pull up on the plastic dash bezel to get the plastic tab out of the slot.
If you could not find the headlight ****/shaft release button earlier. With all screws out of dash and radio loose, you should be able to tilt it forward and see the headlight switch directly behind where the headlight **** is. So with the shaft pulled out like the headlights are on, you tilt the plastic dash bezel forward to get your hand above the switch and feel for a metal button to press and hold to release the headlight shaft from the headlight switch. **** and shaft will slide out as one piece with the button held down.
Cluster assembly is mounted with 4 screws, once they are out, CAREFULLY pull fwd on the assembly just a little. You need it fwd just enough to get a hand on the speedo cable white plastic connector. If you can not get it fwd enough, push yourself some slack in the cable from the eng compartment.
The using your hand (best idea) or a small pair of pliers CAREFULLY squeeze the white clip till the cable comes out of the cluster (the white clip will come with it). DO NOT PRY on the clip it, will break and then you have another issue.
Squeeze the side of the main electrical connector and it should release.
Ing switch, unplug it and then take a flat tip screwdriver and tap in the counter clock wise direction the 3 notch lock ring on the outside.
Cig lighter, un screw the outer cover behind the dash and remove.
Been here yet? https://www.ford-trucks.com/forums/1...then-some.html
