6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Purchasing Advice - Yea or Nay?
Old Aug 7, 2015 | 07:17 PM
Lawdog734's Avatar
Lawdog734
Gents,
I was hoping that some of you might be able to advise on an F250 I'm looking at. It's easy to get wrapped up with how something looks and runs, but the possibility for repairs down the road that cost $$$ leaves me with a slight gut feeling that tells me to move on, as much as it would pain me to do so. I'm a 7.3 guy and this is my first 6.4, so I'm not terribly familiar with them yet.
The truck I looked at is an 08 model King Ranch that looks spectacular. It has obviously been taken care of as there isn't a nick or scratch on it which is all the more amazing since the owner is the 4th owner. The truck looks great and runs great.
The truck has an H&S XRT Pro Street Tuner with a custom tune for milage. The truck also has the EGR and DPF delete and has a 4" turbo back exhaust with 6" tip.The tuner provides for nice, but seemingly not aggressive power but does give a nice puff if black smoke when ya get aggressive with the gas, say to pass a vehicle.
My concern is that I'm not, nor ever have been a "rolling coal" kinda guy - not that it's like that with this tune. What concerns me is that according to the owner, I don't want to mess with switching tunes and if I were to put it on stock mode, as I'm inclined to do, it'll "run like ****" because of the EGR and DPF deletes. Is this something to be concerned about? He said that he had the check engine light come on about a year ago after the deletes, but he reset the codes and it hasn't come back on again.
Is this normal when setting up a truck like this or is it something I should stay away from? Like I mentioned, it's a beautiful truck in immaculate condition, but I'm trying to keep that from blinding me from potential very expensive repairs later on.
Old Aug 10, 2015 | 05:27 AM
senix's Avatar
senix
the owner is right on the tuning. Taking it back to stock would require the emissions components.
If you buy this truck you should get all the emissions stuff in case you need it. Also the tuner and monitor for gauges.
Likely the way it is setup not only provides the power but also the better fuel ecomony.
You should read the tech folder and download the bible (coffee book) as well. That will go along way towards understanding the motor.
the code was likely the P2002 code because he has an aftermarket intake/air cleaner on it.
Old Aug 10, 2015 | 08:40 PM
john410312's Avatar
john410312
I've also found an '08 with 172,000 "highway" miles. Anything I should be looking for out of the ordinary?
Old Aug 10, 2015 | 08:46 PM
senix's Avatar
senix
maintance records and use of oem oil and fuel filters.
See if all the emissions components are in place.
Look the radiator seams over carefully for leaks.
Old Aug 10, 2015 | 09:14 PM
Mud Doc's Avatar
Mud Doc
FWIW--I made it to 207781 with my '09 before #8 piston lost compression. Not wanting to put big $$$ into a high-mileage truck, sold it as is and bought an identical '10 model with 63000 on it.
I had the H&S to get rid of regens, never really saw any mileage gains. I would be very leery of a 4-owner truck with deleted emissions even if it does look like new.
Joe
walter white
Aug 22, 2019 07:34 AM
Khill3253
6.7L Power Stroke Diesel
Aug 24, 2018 07:21 PM
Codelizard
Jan 13, 2018 06:58 PM
SuperDeeDuperDuty
Mar 6, 2015 10:32 AM
DidgeriDood
May 4, 2010 10:29 PM
