upper ball joint question
Old Aug 7, 2015 | 05:50 PM
Dutter 2's Avatar
Dutter 2
So i gotta replace the upper ball joint on my 96 f250 along with the U joint right there. But i was wondering if i could replace it with out separating the lower ball joint by fitting the ball joint press where the the red line is.
Old Aug 7, 2015 | 06:24 PM
My4Fordtrucks's Avatar
My4Fordtrucks
No there isn't room. If I remember correctly it gets removed by pressing from the bottom to the top so at least on my press the lower joint has to be out of the way. I wouldn't just replace one and not the other unless you had already done the lower recently.
Old Aug 7, 2015 | 06:31 PM
GoinBoarding's Avatar
GoinBoarding
You should replace both ball joints and be done with it instead of doing the upper today and the lower next week...
Old Aug 7, 2015 | 06:43 PM
Dutter 2's Avatar
Dutter 2
I'm taking out my drive shaft anyways to replace the u joint so I might have enough room with everything else taken out. And the lower ball joint was done not to long ago according to the Les Schwab receipt I got with the truck.
Old Aug 7, 2015 | 07:03 PM
My4Fordtrucks
On my TTB Dana 44 there wasn't room. The knuckle has to come off either way. Hope it works out for you.
Old Aug 7, 2015 | 07:11 PM
Dutter 2's Avatar
Dutter 2
Alrighty thanks. Yeah just seeing if anyone had tried. Cus in that case I'll just take it off and use my press
Wicked Endings
Aug 22, 2010 06:23 AM
always ford
17
Feb 1, 2010 09:30 AM
mike L
Jun 22, 2006 10:00 PM
MitchPeters
Jul 7, 2004 09:45 AM
