Electrical problems - No Crank/No Start
Old Aug 6, 2015 | 01:28 AM
blackjack33's Avatar
blackjack33
Originally Posted by HIO Silver
Go back to basics and get the simple circuits corrected.
Exactly. Start with the simple things first, they are usually the culprit(s).
Old Aug 6, 2015 | 10:26 AM
jackburtonme's Avatar
jackburtonme
Battery is brand new although the battery cables are in horrible condition.
Sounds to me like you answered your own original question...
12 volt test light is your best friend when working on anything automotive. Tracing power with the light, and under standing 'some' of the electrical system (use a ford truck manual), and you can go along way. Hopefully it's up and running today!
Old Aug 6, 2015 | 05:13 PM
AR78F150's Avatar
AR78F150
Originally Posted by blackjack33
Per the pic of the four post relay, just turn the ignition switch "ON" and check for voltage coming out of the relay.
Here's a pic of the "basic" ignition layout.If you need more details on circuits,etc. let me know.
OMG, this is awesome. Thank you. Unfortunately, no progress on the truck yet but I did an extensive search all day long. It is as hot as hell outside, I am waiting to get it cooler.
Old Aug 12, 2015 | 04:00 PM
AR78F150's Avatar
AR78F150
Thumbs up Update: Problem solved
The culprit was the battery cables. I also sanded the engine ground connection behind the alternator and the sheet metal behind "real" starter solenoid ground. I am not really happy with the new zinc battery terminals because they are flimsy but they are allegedly more conductive than the lead terminals. The new wiring harness is arriving tomorrow, I am excited . Thanks to everyone helping me on this issue.
blue76
Jul 1, 2016 07:23 PM
Beedub109r
26
Sep 24, 2014 07:35 AM
67Farm100
Apr 7, 2006 06:05 PM
Rossta86
Electrical Systems/Wiring
Oct 18, 2005 07:51 PM
kevinken
1978 - 1996 Big Bronco
Mar 25, 2003 10:25 PM
