Radiator size
Old Aug 4, 2015 | 08:59 PM
Carmax's Avatar
Carmax
Radiator size
Will a radiator used with a L6 300 work fine with a 351w?
Old Aug 4, 2015 | 09:23 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Good question. I've noticed the radiator in my one truck with the 300 is WAY smaller AND thinner than the radiators in either of my 352 trucks. And, despite that, the 300 still seems to run cooler than either of the V8 engines. Two more pistons and some extra cubes at least. Might also be more friction in a V-8 with the lateral movement of the pistons in the bore.
Others will chime in, I'm sure.
Oh, the 300 also has the Extra Cool Radiator, whatever that gave a person. You can see it on the invoice in my album here. But, so did both of the V-8 trucks so that's a wash.
https://www.ford-trucks.com/g/picture/3332955
Old Aug 5, 2015 | 03:15 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
As I recall, the I-6 radiator has the upper neck on the opposite side vs. the V8 radiator.
The radiators used in 1965 F100/250 2WD's are different than the radiators used 1966/79, as the '65 F100/250 2WD radiator support is different, so the radiator mounting flanges are in a different location.
btw: L6 is the designation for a Flathead 6, not installed in Passenger Cars/Trucks after 1951, as the OHV I-6 (215 cid initially) was introduced in 1952.
Old Aug 5, 2015 | 07:19 AM
Carmax's Avatar
Carmax
So it would really just mean a passenger side water pump neck and the routing of the radiator hoses?
Old Aug 5, 2015 | 07:21 AM
Carmax's Avatar
Carmax
Im just making sure the radiator off the L6 will be efficient enough for the V8
Old Aug 5, 2015 | 11:58 AM
daveengelson's Avatar
daveengelson
The 65 with the T-18: swapped a 302 for the 300 in late 70's and kept the same radiator and never experienced an overheating problem. Fortunately able to refer to a later model truck in finding inlet/outlet size hoses for the correct location. If already have, or intend, adding auto trans then may want to consider going with radiator that includes the trans cooler. Having said than, finding a replacement can be problematic? If don't intend adding auto trans, knowing what I know now, I would see if the existing radiator would supply sufficient flow to maintain proper heat for the 352?
Old Aug 5, 2015 | 02:03 PM
Carmax's Avatar
Carmax
Inhave a c4 with a seperste cooler so i dont believe the trans should be a problem
Old Aug 5, 2015 | 02:05 PM
Carmax's Avatar
Carmax
At the worst case id just have to get unmolded radiator lines and route it however possible
benwantland
Jan 29, 2023 06:35 PM
idealtrucks
Sep 5, 2013 10:48 AM
livinjeep
Apr 30, 2012 07:39 AM
hivolt5.0
Aug 17, 2008 08:49 PM
mustangmaniac
Nov 18, 2003 04:07 PM
