Need help ASAP! stalled twice already
my 2004 f150 fx4 5.4 triton started a knock, then within a week or two it kept getting progressively worse, especially when accelerating, eventually once the tuck was warmed up and would begin to decelerate it stalled, it will still start and run but i have not driven it since, what could be the issue?
you need to do some more looking at the truck and seeing if there are any codes. When you say "KNOCK" do you mean chugging due to misfire ? That could be COPS. New plugs is always a good idea. When it died, do you have fuel pressure ? When you turn the key , do you hear the fuel pump run for 3 seconds ? Could be a weak pump. Could be a failing fuel module. Need more info on "Knock".. Start the truck and let it idle.. does it "knock", does it have oil pressure, does it stumble ?
