kingpin replacement
Old Aug 1, 2003 | 03:29 AM
85f-250-460's Avatar
85f-250-460
kingpin replacement
Any pointer's on replacing kingpins in the truck. Is there a right
side up or wrong side up for the bushings? What things do i needed to watch out for so i don't mess this up sense this my daily driver. All my tie-rods are in good shape as is the pitman arm. I know that i will needed to get a front end alginement done on the truck after this done. What else am I missing? Do need any special tools at all? Other then one big hammer and a case of beer
This a 85 F250 (8700lbs) 4x2 with a 460.
Thanks guys.
Old Aug 1, 2003 | 11:32 PM
85f-250-460
kingpin replacement
hey guy's, could use some help here! need to know which way the bushings go in and all the good stuff
Old Aug 2, 2003 | 02:24 AM
85F_150driver's Avatar
85F_150driver
kingpin replacement
You will also need a big torque wrench and a bigggggg pipe because they are torqued, to according to Haynes Manual, to 500 to 600 ft-lbs and will require a 3/4 or 1 inch breaker bar and cheaterbar for sufficent leverage. be sure the truck is securely raised and be sure not to topple it off the stands. I replaced teh ball joints in my 85 f-150 and my 12 dollar haynes maual was a life saver i recomend picking one up it also shows how to re assemble the king pins pushings and springs and other such things. Good luck, Ben
P.S. may require two cases of beer
Old Aug 2, 2003 | 06:10 AM
85f-250-460
kingpin replacement
thanks 85f-150ddriver,
I knew that I was forgetting something I totally forgot the amount of torque.
pastelsand
Aug 29, 2014 11:09 PM
Nick_Good
Mar 2, 2010 06:06 PM
TheFixer
Sep 15, 2009 06:18 PM
jackndelphine
Mar 5, 2009 11:48 PM
whalerron
Nov 10, 2004 09:46 PM
