Racor PS120
Racor PS120
Replaced the Baldwin filter setup that came with the Sinister diesel Hutch kit with the Racor PS120-2 yesterday. I initially thought it was redundant to install such a high filtering unit in front of the fuel pump when OEM did not. This filter (Tip to Tugly for the heads up this filter exists) restores the filtration to OEM design but with a much larger screen filter setup one can see and maintain far more easily than the stock setup. Bolted right in place of the Baldwin setup using the Sinister stainless brackets. Just knocked out the three studs and drilled 2 holes a bit larger for 1/4 inch carriage bolts. They are a bit long but...they don't affect anything.
Hamberger
02-16-2011 09:17 PM
Hotwheelbill
36
03-21-2008 02:25 AM
jtharvey
02-22-2007 12:31 AM
