Cleaning Exhaust Filter
Where do you get this app and how is the android device reading the sensors?
works great
The owners manual and Diesel supplement are equally useless when it comes to understanding the clean exhaust filter light. I have six other Ford diesel pick ups two being power stroke seven threes but this is my first 6.7. It's 2015 F2 50 that I bought new in July and the light actually came on on the way home from the dealership and there was no explanation about it at the dealer. I still don't know how long it takes but every time sense that it has come on even if I'm almost home or where I'm going I keep on rolling down the highway for a Waze until I think it might be done . I think I'll get the scan tool yeah why didn't Ford just put another idiot light on the dash. Other than that I absolutely love the truck and the motor is amazing
I have found I need to run above 1500 rpm. I run in 5th gear rather than 6 even when pulling. Otherwise the filter will plug.
The OP didn’t say what year his SD is so not sure of the following for him. The regen msg doesn’t display in ‘17 and newer trucks but does in prior SDs, although briefly. You can have the dealer install the Regen gauge in the dash display so you can see where you are in the cycle.
I got stopped for DEP inspection becuase my truck puffed smoke for more than 3 seconds during regen.....passed the under carriage and had current emissions test so I got a warning in writing rather than the 700 dollar fine for the 1st offense and the automatic inpound for the second offense.
how would I pass my annual diesel emissions inspection and my curtesy under carriage check for emissions equipment when a DEP office counts 3 seconds of puffed smoke upon take off.
I got stopped for DEP inspection because my truck puffed smoke for more than 3 seconds during regen.....passed the under carriage and had current emissions test so I got a warning in writing rather than the 700 dollar fine for the 1st offense and the automatic inpound for the second offense.
I also don't puff smoke. I tried "rolling coal" just for grins but can't get even close to it.
Long drives daily getting old
If it is reporting "drive to clean exhaust" and then "cleaning exhaust filter" some time later, go for a long drive. You can keep an eye on your instant MPG screen to know when it's still going and when it's done. Know what the graph looks like normally and then the graph should be significantly lower at highway speeds while in active regeneration.
Lots of short trips do not allow the DPF to heat up enough to turn the soot into ash. Take it for a long drive often.
Thbis is not normal. Sounds like you need to get your truck checked out. Mine has only shown me that warning once in 7 years.
