Spent some time doing a bit of tweaking to both of the drivers bezels (with and without power mirrors).
I've added a chamfer around the window and lock switches that some stated could interfere with switches. I could never find out why some switches seemed to have an issue and others didn't - so I fixed it across the board.
Just checked on getting the multicolor jetting done. absolute insanity at nearly 500$ a bezel to do two colors at once.. It may be possible to get the bezel lettering recessed and then print the actual white letter separate and combine later - more time more time.
P.S. for anyone wondering, the closest font I could find to the original "WINDOWS" and "DOOR LOCK" was the 'Wyvern Heavy' typeface.
Needs to be widened a bit to match 100% but its as close as i could find.
About as close as it gets. spacing between the N, D, and O is a bit off, but that could simply be bleedover from the silkscreening process probably used to get this done.
Never knew that these were so hard to come by.
In fact, I didn't even realize until today that I have a somewhat decent CC drivers door panel in light gray and the OEM switch bezel within my OBS stash.
I have found the driver side bezel
but I was wondering if you make the passenger side also
I have new door panels and if I get the new bezel for the driverside it would be nice to get a matching one for the passenger side.
if you can let me know that would be great
thank you
