HELP no reverse lights and tail lights
Old Jul 31, 2015 | 06:36 PM
Trent Racer's Avatar
Trent Racer
Exclamation HELP no reverse lights and tail lights
i have replaced headlight switch and the connector and checked all the fuses and i still get nothing so i am lost on this
any solutions will be appreciated
this is a 1989 f250 351w c6 for the record
Old Aug 1, 2015 | 07:52 AM
tjc transport's Avatar
tjc transport
i ain't rite
reverse lights are controlled by the switch behind the shifter lever on the side of the trans. 4 wires, two for neutral safety switch and two for reverse lights.
purple/orange should be hot with key on, powered by fuse #5 in the fuse box.
black/pink should be power out of switch when in reverse to the rear lights.
as for the tail lights out, it is possible that the tail light filaments of the rear bulbs are both bad..
Old Aug 10, 2015 | 08:52 PM
Trent Racer
turns out it we had to make a new wiring harness cuz the previous owner had replaced the bed cuz the dumb *** was smoking a cigarette and dropped it when gas splashed out the tank and caught on fire and the wiring finally just shorted out cuz it was so brittle
Old Aug 10, 2015 | 10:25 PM
Shadow944795's Avatar
Shadow944795
Easy on the curse words friend.
BigDaniel
Jun 15, 2018 09:19 AM
granny_rocket
Mar 4, 2015 06:54 PM
drawtiteboy2
2004 - 2008 F150
Dec 17, 2014 05:47 AM
73 fourxfour
13
Oct 13, 2011 02:20 AM
Ford1978F-150Ford
Oct 22, 2003 04:04 PM
