Sponsored by: Real Truck
Rear end shudder
Old Jul 31, 2015 | 07:06 AM
ClinchValleySD's Avatar
ClinchValleySD
Rear end shudder
Hello all in Ford Truck Land
The 2004 SD that I've had now for about six weeks seems to be doing really well, after spending some bucks on wear items. It's doing something, however, that reminds me of a TractionLok that I had built for the '67 Fairlane: rear end shudders in slow turns or pulling one of the curvy roads up the ridges around here. Could I be on the right track with this idea? Haven't checked if it's a LS diff yet.
Thanks...
-Jon
Old Jul 31, 2015 | 08:58 AM
r2millers's Avatar
r2millers
Yep, sounds like a LS rear end.
I'd drain and refill with the approp, gear oil and add friction modifier.
Old Jul 31, 2015 | 09:05 AM
ClinchValleySD
Thanks. Just happened to remember that the other day, that one would make the whole car shake! Had some friction modifier put in when I had an oil change a couple of weeks ago, but prolly does need new lube with another shot of FM. One of the items on the list!
Jon
Old Jul 31, 2015 | 09:22 AM
r2millers's Avatar
r2millers
Doesn't sound like it but the tranny can shutter too. Normally it's when shifting up, into overdrive, and not necessarily when turning.
Kinda feels like running over Bots Dots when approaching an isolated stop sign.
I'd start with the new gear oil and modifier.
Good luck.
Old Jul 31, 2015 | 09:42 AM
ClinchValleySD
Yeah, I have a friend who had a '94 F-150 that would do that. This is turning slowly, like in a parking lot. Looks like somebody may have been into it (rebuild?), so that is on the to-do list. Along with the trans, coolant, and other good stuff.
Thanks again!
Jon
Old Jul 31, 2015 | 12:13 PM
droldsmorland's Avatar
droldsmorland
After the fluid refill with modifier do a few figure 8s so the new fluid gets into the clutches. Takes longer to get in there if you dont.
Old Jul 31, 2015 | 02:55 PM
SteveH-CO's Avatar
SteveH-CO
My truck shuddered on takeoffs (especially slightly angled takeoffs) and I found that the rear-most u-joint was shot. Replacing that, and lubing the splines with the PTFE Ford lube transformed my truck to feeling 'like new' on takeoff.
Old Aug 3, 2015 | 04:30 AM
ClinchValleySD
Sorry I haven't replied. Thanks for the advice, guys! That's why I joined, for the knowledge and experience with these trucks as this is my first one.
rsyauto
May 1, 2010 12:16 PM
Scolesy8
Nov 18, 2008 08:02 PM
pstrang
Jul 25, 2007 12:15 AM
dieseldude89
Apr 9, 2006 01:45 PM
radrob
1983 - 2012 Ranger & B-Series
Jan 18, 2005 11:22 AM
