1997 E-350 A/C compressor
Old 07-29-2015, 09:15 PM
R T's Avatar
R T
R T is offline
I need to get a new compressor for the a/c in my 1997 E-350. What is the best one to buy?
Old 07-29-2015, 10:12 PM
98Econoline150's Avatar
98Econoline150
98Econoline150 is offline
Go to rock auto and get a MotorCraft compressor, they are usually under $200 while they are almost $600 from Ford.
Old 07-30-2015, 05:37 AM
JWA's Avatar
JWA
JWA is offline
Received 1,412 Likes on 1,113 Posts
For under $200 the MotorCraft would be a great deal.
If budget permits think of replacing the line set too---both Dorman and Four Seasons make nice replacement assemblies.
In fact given your year chassis and assuming the A/C system is all original I'd strongly recommend replacing everything but the evaporator and condenser coils. Serpentine belt & tensioner, accumulator/dryer, Schrader valves, service port closure caps (plastic) along with the compressor and line set---you'd have a nearly new complete A/C system.
Sounds like a lot at first but if you need or require A/C the difference a few new parts makes is pretty much worth the time and expense. On my 2000 E250 with 275K miles the new system produces 38* leaving air temps even on 90+ plus midwest humid days.
HTH
Old 07-30-2015, 10:45 AM
R T's Avatar
R T
R T is offline
Thanks for the advice! Motorcraft for the compressor, and I will replace the accumulator/dryer, Schrader valves, service port closure caps (plastic) along with the compressor and line set. Good advice!
Thanks!
bigTEE56
09-29-2013 10:20 AM
rickfar
Escape & Escape Hybrid
04-15-2011 09:18 AM
TheRobIdentity
Aerostar
08-05-2006 04:30 AM
cookkd
Aerostar
06-14-2006 07:58 PM
fogerson
04-19-2006 10:47 AM
Quick Reply: 1997 E-350 A/C compressor
