f150 bad compressor
Old Apr 18, 2006 | 06:54 PM
fogerson's Avatar
fogerson
f150 bad compressor
My factory a/c compressor broke 4 years ago and a aftermarket one was installed. It worked for a short period of time and then broke. A replacement was again put on (for free) and it didn't even last a day. At the time I was told I would have to replace all the lines condensor drier and compressor in order to make sure it would work. The compressor and drier I understand but he said because of the compressor failure the small pieces of metal are stuck in the lines and condersor. Is this true? and if so where could I find the lines and cheaper than at dealership. Thanks Bill
Old Apr 18, 2006 | 09:33 PM
Ultramagdan's Avatar
Ultramagdan
Ouch! Having metal in the system is not good. A quick search on Google can provide you with several sites with good prices.
Old Apr 19, 2006 | 10:47 AM
lsrx101's Avatar
lsrx101
Ouch. You've got the classic "black death" from the first failed compresor. The condenser is most likely plugged. It's usually best to do a "firewall foreword" replacement to prevent future problems. The evaporator is probably ok. You can use the parts from a donor vehicle with a known good system to save cost, just use a new accumulator.
redstang
1983 - 2012 Ranger & B-Series
Aug 20, 2010 01:45 PM
thesprocket26
Nov 4, 2005 03:54 AM
Lakeitel
Jul 31, 2003 07:00 PM
