Sponsored by: Real Truck
need some input;very confused
Old Jul 29, 2015 | 09:37 AM
JosephDunivan's Avatar
JosephDunivan
my wife and i own a 2002 f350 7.3 crewcab normally in town it dosent use any oil,we took a 210 mile trip pulling our 35ft travel trailer and the truck went though a gallon of oil.... what gives?
Old Jul 29, 2015 | 12:06 PM
RV_Tech's Avatar
RV_Tech
No sign of a leak?
Old Jul 29, 2015 | 12:31 PM
Chuck's First Ford's Avatar
Chuck's First Ford
some brands of oil ,,, evaporate and quickly under a work load...
have you changed brands of oil????
sometimes a clogged oil filter can increase the use of oil!!! I am NOT saying this IS your problem... just some history for oil and filters....
Hopefully you did not NEED to add a Gallon all at once!
Old Jul 29, 2015 | 11:02 PM
JosephDunivan
im useing a sysnthedic hd diesl oil , and yes it was a gallon at once and my cold air intake tube drivers side is saturated in oil as well /////////??????????????????
Old Jul 29, 2015 | 11:06 PM
JosephDunivan
yea it was a gallon
whats ever stranger is my cold air intake feed tube on the drivers side is covered in oil......
Old Jul 30, 2015 | 11:41 AM
droldsmorland's Avatar
droldsmorland
PVC? Turbo? worn out engine components? ....Somethings sucking in the oil or its getting past rings and seals...as its doesn't just evaporate. Its using it somehow. Oil consumption occurs 3 ways: Its getting past piston rings or valve guides; its being sucked into the intake track and being consumed or there's a leak. Any puddles under it? Check the inlet to the turbo for oil, it should be dry. If you see oil the turbo seals are wearing out. Which would coincide with the heavy loading it just saw on your recent trip. How many miles on the rig?
Old Jul 30, 2015 | 02:55 PM
KellyfromVA's Avatar
KellyfromVA
I vote clogged PCV or blown turbo seal.
Old Jul 31, 2015 | 09:34 PM
JosephDunivan
thank you everyone for the help..... would a blown turbo seal couse oil saturation of the dr side cold air intake sheild?
Shorty Thompson
Nov 19, 2018 08:24 AM
pawpaw
Oil & Lubrication
Mar 22, 2016 11:05 PM
robinsonpowerstroke
Dec 7, 2009 08:58 PM
99 7.3 towrig
May 6, 2007 10:10 PM
davidrobertaw
Mar 14, 2006 05:27 PM
