AC mod assistance
Old Jul 28, 2015 | 11:49 AM
Jaime74656's Avatar
Jaime74656
AC mod assistance
well seeing as my truck may have a bad torque converter and I really don't have the tools to pull the trans [see other thread on that issue] (and the heat is not really making this easy) and I have all the parts to do the AC mod (heater shutoff valve and all that) I figure I might as well do something simple and easy to get me onto happy thoughts...now only thing i am having issues with is determining the flow direction, all the pictures show the (looking from front to rear) the left side (passenger most side) of the heater core as the intake, can someone confirm if this is correct or if this is not correct? thanks!
if I need to I can get a better pic of the lines.
anyways I am greatful for the brotherhoods help with the issues I have needed help and hope to continue providing what help I can
Old Jul 28, 2015 | 02:27 PM
guitarpicr's Avatar
guitarpicr
Are u installing one valve -I wouldn't think it would matter which line u put it on- Either way it will stop flow thru heater core, but I could be wrong. If nothing else a bump to the top for ya.
Old Jul 28, 2015 | 02:57 PM
F250_'s Avatar
F250_
Doesn't matter which line. Stopped flow is stopped flow, regardless of which side of the heater core you're on.
One suggestion, though. If you use common worm clamps, check them again once it gets cold because they will probably leak otherwise once the weather turns cold.
Old Jul 28, 2015 | 03:28 PM
Jaime74656's Avatar
Jaime74656
cool, and I know stopped flow is stopped flow, but let me retry the question which way does the flow go? is a better question as I want the arrow to be pointed in the correct direction (I understand it may ot may not matter but just for the sake of my knowledge I want to at least know
Old Jul 28, 2015 | 04:28 PM
F250_'s Avatar
F250_
OK. Fair enough. New information makes fro a completely different context. I'll see if I can scare up a diagram to confirm the flow direction.
Haven't found a good diagram, but one I did find indicated that the return line is the one going into the top of the water pump. Heck, if you find out later it's the other direction, just flip the valve around.
Old Jul 28, 2015 | 07:41 PM
Jaime74656's Avatar
Jaime74656
Understood F250, I may try and scare one up when I go into work on the 30th also
Old Jul 28, 2015 | 11:02 PM
cj45lc's Avatar
cj45lc
The hose coming from the passenger side head is the in to the heater core & the return is the hose that goes to the waterpump.
Old Jul 29, 2015 | 09:22 AM
Jaime74656's Avatar
Jaime74656
Ok so then flow wise the inlet on the passenger side of the truck(looking from front to back) is in and the side closest to driver side is out
Old Jul 29, 2015 | 09:56 AM
F250_'s Avatar
F250_
If both cj45lc and I are right, the driver side port (looking at the firewall from in front of the truck) should connect to the nipple on the top side of the water pump.
BTW... I have found verification that it the heater core "cold" ("return") hose definitely attaches to the top side nipple on the water pump.
Old Jul 29, 2015 | 10:07 AM
cj45lc's Avatar
cj45lc
I just went out & looked at my truck & it just the opposite of what you are saying. The inlet (hose coming from head) is the hose on the right in your pic, closest to driver side. I remember having the same concerns when I put the shut-off valve on mine a few years ago & it may not make much difference but I did want the valve on the supply side of the heater core lol.
Old Jul 29, 2015 | 10:10 AM
F250_'s Avatar
F250_
OK, then. The hose connecting the PASSENGER side port is the one which goes to the top nipple on the water pump, and is therefore the "cold" return hose. The "hot" supply to the heater is connected from the engine head to the driver side port at the firewall.
Old Jul 29, 2015 | 10:15 AM
cj45lc's Avatar
cj45lc
that's the way my truck is, you guys got my curious up until I had to go look just to satisfy myself hahaha
Old Jul 29, 2015 | 11:56 AM
Jaime74656's Avatar
Jaime74656
well its not really going to matter to me, its more I want the arrow to poit in the direction of flow for the fluid (as the thing has a directional arrow) and figure if I know the flow that will help...I plan to add a second valve to isolate the heater block completely so no flow goes to it (yes I know I hear some already screaming "WHY?" it just makes more logical sense to have two valves to isolate the heater core compleatly and have a way to recirculate to the engine instead
Old Jul 29, 2015 | 01:23 PM
cj45lc's Avatar
cj45lc
I hear you about the flow arrow, the valve I used had the arrow & I was like you & wanted it in the stream accordingly. I got the one I used from NAPA & just put it in the supply hose but they did have one that would have gone in both hoses & when activated would have allowed the coolant to make a loop through the valve itself.
Old Jul 29, 2015 | 05:35 PM
Jaime74656's Avatar
Jaime74656
I might look into that type then
