When to Replace Injector Cups
Old Jul 28, 2015 | 11:31 PM
Thomas White's Avatar
Thomas White
Originally Posted by caedo
And what updated UVCHs are you speaking of?
Thanks!
Old Jul 29, 2015 | 06:29 AM
Tugly's Avatar
Tugly
This is my official test procedure - it has given instant results on more than one truck:
  1. With injectors out - drain the radiator, then drain coolant from the block (I pulled the plug-in heater next to the oil filter).
  2. Leaving the degas cap on - pull the small hose from the driver side of the degas bottle and cap the hose with a bolt or pen.
  3. Have a "volunteer" puff up the radiator with a rubber-tipped nozzle from an air compressor until the cap lets you know it's at max (it won't be subtle).
  4. Spray silicone spray (benign to the engine and sealant) into each cup and watch for bubbles. If the cup is at an odd angle, use a video camera (like your cell phone).
Here is an example with an inspection camera:
Old Jul 29, 2015 | 07:31 AM
caedo's Avatar
caedo
Great! Looks pretty easy and i'll change to ELC while I am at it. Thanks Rich!
Old Jul 30, 2015 | 07:11 PM
F350-6's Avatar
F350-6
The cracked cups I've seen you could actually watch the water droplets form and then run down the cup with no additional pressure required.
Adding small amounts of pressure to the coolant system will help you see if there are any cup issues.
Old Jul 31, 2015 | 07:44 PM
bigb56's Avatar
bigb56
Originally Posted by F350-6
I'd replace them when they fail (unless you have an early model engine and switched to ELC coolant, then I'd get out in front of it)
I replaced my factory injectors back around 300,000 miles. Left the factory cups in place. Now sitting over 515,000 miles and the factory cups are still doing just fine.
That is music to my ears. I have a 2002 as well with 163K on it right now and I am hoping to get the same life out of it as you. My miles are about 75% highway and I am meticulous about maintenance and fluid changes. My truck has never seen a programmer or chip either, what about yours? Not saying there's anything wrong with the right tunes but I figure if I am happy without them why do it?
Old Jul 31, 2015 | 08:01 PM
F350-6's Avatar
F350-6
I've got a chip from Tony. I put it off for a long time, but got tired of listening to him give me a hard time about it so I tried it out. Decided to keep it since it was more funner.
Old Aug 1, 2015 | 07:50 AM
Tugly's Avatar
Tugly
I have the same experience, but I also had a bad cup seal that passed the pressurized coolant test... the air test caught it. Coolant is easier to seal than fuel or air. Think of it in terms of penetrating oil vs. 30 wt.
Old Aug 1, 2015 | 11:01 AM
F350-6's Avatar
F350-6
On factory cups, or cups that had been installed later? I wouldn't expect seal issues on factory cups unless it was an early truck that was running ELC.
sand_fiend
107
Sep 26, 2022 07:47 PM
queen of spades
Apr 24, 2021 11:51 AM
53fordman1
Sep 26, 2020 12:40 AM
brian42
33
Jan 17, 2018 11:24 AM
tjc transport
16
Jan 17, 2015 09:39 AM
