72 fix what was wrong
Old Jul 27, 2015 | 12:15 PM
PAR34's Avatar
PAR34
I bought a cool 72 back a couple of years ago, had a Fatman's front end installed and IRS from a Mark VIII, the motor was warmed over, which I saw paperwork confirming what was done from a machine shop. It took me some time to realize a lot of this work was installing incorrectly.
Old Jul 27, 2015 | 12:20 PM
PAR34's Avatar
PAR34
Checked the Fatman's install and that was put in correctly, swaybar wasn't as it was hitting the rod ends, also the rack was shot, so that was an easy fit, the big thing was why were the inner fenders cut out? The previous owner said it looked cool....Not! Looks like when the suspension was maxed out the tires hit the inner fenders.
Old Jul 27, 2015 | 12:28 PM
PAR34's Avatar
PAR34
Found a set of NOS inner fenders on evil bay for $200 plus shipping, which I thought was more than fair, bolted them up but would have to alter them to make it work.
Old Jul 27, 2015 | 12:34 PM
PAR34's Avatar
PAR34
Time to make some mini tubs
Old Jul 27, 2015 | 12:39 PM
PAR34's Avatar
PAR34
Fab up some sheet metal
Old Jul 27, 2015 | 12:51 PM
Freightrain's Avatar
Freightrain
Nice work.
That is the difference between "making it work" and "making it right".
Looks like you get to spend more money on car parts then mowers/gas LOL!!
Old Jul 27, 2015 | 01:08 PM
quinletc's Avatar
quinletc
Great looking truck! And nice to see you "making it right!"
Old Jul 28, 2015 | 07:29 AM
PAR34's Avatar
PAR34
Sent the inner fenders out to body shop for finishing and paint. I was going to weld the tubs in but the body guy said he would use panel bond to do the job. This stuff is super strong and holds forever. Also repainted the block changed alt bracket and new power steering pump brackets, also new MSD Distributor, hey it's only money!
Old Jul 28, 2015 | 07:52 AM
f100today's Avatar
f100today
Looks good. This is why I decided to build my own truck. I got tired of Buying stuff I thought would work for me then end up changing or fixing half the the stuff on the truck. I use plio grip which is the same as panel bond. Stuff is great and keeps the heat out of the metal. Yes it will last forever as you stated. PG has seam sealers that work great for body seams as well. Way better than welding and grinding. I have a Mii under my truck like you. I ended up fabbing my own inner fender wells for tire clearance. My front tires are 30.5 tall so I had to overcome that tire height. Your truck looks great.
Old Jul 28, 2015 | 08:04 AM
Uni Moe's Avatar
Uni Moe
Power steering pump and alt brackets look much better than the crap that was on there. Nice work.
Old Jul 28, 2015 | 08:31 AM
PAR34's Avatar
PAR34
Thanks for the positive input guys, f100 today I agree with you and if I could start again I would just start with a clean stock truck. I will post what I had to do to the rear of this truck, which was a major screw up by the previous owner. Oh yeah replaced water pump too. Just want it right and no worries in the future. Now for the hard stuff complete rewire....
Old Jul 28, 2015 | 07:24 PM
JEFFFAFA's Avatar
JEFFFAFA
Man those inners look Good. Looks like you made 'em just wide enough to cover full suspension at full steer too. Good Job.
Old Jul 29, 2015 | 07:44 AM
PAR34's Avatar
PAR34
Thanks Jefffafa, they look so good people don't even notice them.
The front of the truck wasn't too bad to get right but the rear IRS install took some work. The rear was installed poorly and cross members were cut out so when you pushed the truck at speed in a corner there was a very uneasy loose feeling due to the rails flexing. The welds looked really cold no pen, not to mention the brake line that were not mount and rubbing because they were run through holes in the frame.
Old Jul 29, 2015 | 07:48 AM
PAR34's Avatar
PAR34
Time to redo the rear.
Old Jul 29, 2015 | 07:56 AM
PAR34's Avatar
PAR34
I didn't like the shock mounts and there were two different shocks installed by the guy...ugh! Got carried away with stiffing up the rear. Team 321 recommends 1 -2" x 2" square box channel across the rails to do the job, just did something a little different. Also built a skid/cage to help stiffen and protect the rear mounted gas tank. Also found the gas tank was not vented.
