04 f350 loose injector
I had the number 4 injector come loose a few days ago the truck started missing and then died. i tried to start it it was hydra locked. I had no idea what was wrong with it i almost cried like a baby . So i called a friend that knows alot more about these trucks than i do he said if your coolant level is good then its probably an injector gone bad he said to pull the glow plugs and bump the engine over and you will find the bad one he was right number 4 . pulled the valve cover and sure enough it was loose. Replaced it along with new glow plugs and harness. Cranked it over for about 20 seconds it fired right up smoked ALOT for about 10 miles but ran good. its been a few days now and all seems good. I like this truck better than any other ive ever owned but man it worries me some times.
I bought the truck in Feb its got 93 k on it i had an oil cooler and egr delete done when i got it. I noticed when i had the ficm off it had been replaced it had the dates scratched off the tag april of 2014 other than that i dont know much about it. Thats a good idea ill be checking the fuel pressure
If you come up with sub optimal pressure for the fuel
you will want to get a blue spring update pressure regulator installed.
Not a hard job. Just search for Blue Spring.
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
Shawn MacAnanny
22
10-30-2016 04:25 PM
Oleblue96
09-12-2016 10:44 AM
materthegreater
32
08-11-2014 07:17 PM
