2004 explorer rear axle ?
Old Jul 25, 2015 | 08:08 AM
nussford's Avatar
nussford
My 04 explorer rear axle is howling and is time for a rear build or new one. Is it possible to switch the expedition 8.8 IRS rear axle in because I haven't seen too many with the very common rear axle problem the explorers have. Or would I better to rebuild mine. If so could I get a parts list of what's needed and where to buy. Thanks in advance.
Old Jul 25, 2015 | 04:01 PM
nussford's Avatar
nussford
And when I say switch to the expedition rear axle I mean just the center section.. Im not positive but I believe all I would need to swap is the rear cover because the explorers I know are different just not sure on the front pinion mount.
Old Jul 26, 2015 | 12:49 PM
steve(ill)'s Avatar
steve(ill)
https://www.ford-trucks.com/forums/1...e-rebuild.html
pinion and ring gear bearings are standard 8.8 parts.. there are two additional roller bearings that support each half shaft as they enter the pumpkin, just a couple inches from the ring gear support shaft. I bought all on e-bay.
Old Jul 26, 2015 | 10:04 PM
fordmerc's Avatar
fordmerc
The expedition IRS is not a 8.8. I believe it is a 9.75
havi
18
Apr 16, 2010 09:48 PM
cher96
Jun 8, 2009 12:01 PM
Vee
Oct 9, 2007 04:20 PM
paul812
1997 - 2003 F150
Nov 28, 2005 05:43 PM
