cam swap ???
Old Jul 24, 2015 | 06:20 PM
goose_ss4's Avatar
goose_ss4
cam swap ???
I was curious to know if anyone had swap a camshaft into an engine while it was in the truck? My recent rebuild has front cover leak, so I was thinking swapping the cam while I was in there thanks!
Old Jul 24, 2015 | 07:32 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
iv got to replace the rad support on chip truck at some point.at that time,when the front is open,the torque cam will be going in.
Old Jul 24, 2015 | 09:06 PM
Ford F834's Avatar
Ford F834
Yes, it is possible to do. The steps are even in the Haynes Diesel Tech manual if you happen to own that. The main thing if you don't take the front clip off is to get the radiator and vertical core support brace out of the way so the camshaft can be pulled out through the front. Depending on the year of your truck and how it is equipped, you often can't get the rear pushrods out of the passenger side because they hit the heater/AC box. But you can still get the lifters out and hold the pushrods out of the way as you put the new camshaft back in. It is pretty major surgery but definitely possible with the engine in the truck...
NCMillwright
5.0L Coyote
Nov 12, 2018 07:35 PM
klujaan
Oct 27, 2018 01:37 PM
68cabby
26
Sep 13, 2012 06:44 PM
neomac3444
3.0L V6
Apr 16, 2007 06:24 PM
mattskn
Dec 30, 2004 08:44 PM
