4x4 issue
Old Aug 2, 2015 | 12:53 PM
alloro's Avatar
alloro
Originally Posted by Welder7018
How do i go about seeing if the hubs engage? This is my first 4x4 with non locking hubs. Im used to old school 4x4.
Jack each front tire off the ground one at a time. Start the engine, leave it in park and shift into 4Hi. While the tire is off the ground it won't spin if the 4WD and hubs are engaged. If the tire spins freely then something is wrong.
Old Aug 2, 2015 | 06:00 PM
Welder7018's Avatar
Welder7018
4x4 issue
Ok ill try that.
Old Aug 6, 2015 | 08:09 PM
Welder7018's Avatar
Welder7018
4x4 issue
Hubs lock, 4x4 works now had a loose vacuum lines going to the hubs. But light dont come on. As long as the 4x4 still works im fine.
Old Aug 8, 2015 | 08:31 PM
alloro's Avatar
alloro
Could simply be a bad bulb.
Old Aug 8, 2015 | 08:41 PM
dclack's Avatar
dclack
The light should come on when you turn the key to 'on'. Mine does, and the hubs lock and unlock as they should; but the light does not come on with the switch.
Old Aug 8, 2015 | 08:43 PM
alloro's Avatar
alloro
And you're sure it's engaging the front drive shaft, or are you only seeing the hubs engage?
Old Aug 8, 2015 | 09:04 PM
dclack's Avatar
dclack
Yeah, I tested it the way you described above and both tires are free in 2wd and locked to the trans in 4wd.
Old Aug 8, 2015 | 09:07 PM
Welder7018's Avatar
Welder7018
4x4 issue
It works i think its a bad contact switch or something in the shift motor since it comes on during intotal start up when all lights come on.
Mine dont its a bad contact or switch in the shift motor. I put the truck on a friends lift at his house and put it in 4x4 high and all 4 moved even when i gave it throttle. Toom it out of 4x4 only back spun. I also tested it in his field got a bit dirty and 4x4 works as it should.
Old Aug 9, 2015 | 08:59 PM
alloro's Avatar
alloro
Well if you're happy then I'm happy.
Old Aug 9, 2015 | 09:06 PM
Welder7018's Avatar
Welder7018
4x4 issue
I am, thanks for the help! I would not have thought a cracked vac line could irritate me so much lol. Next step fix the backup aid.
jrbowman02
Sep 13, 2018 09:15 PM
bbdano
Apr 1, 2016 09:33 AM
chimchim
1997 - 2003 F150
Mar 28, 2011 01:11 PM
ironarmscott
Jan 20, 2011 04:29 PM
TheRadioMan
1978 - 1996 Big Bronco
Nov 13, 2003 09:25 PM
