1978 - 1996 Big Bronco
engine temp ?
Old Jul 31, 2003 | 04:18 PM
89broncobob's Avatar
89broncobob
engine temp ?
The bronco is not over heating .but when im on the highway doing above 65 the temp go's up to about 215 or so .the gauges are after market .like i said its not over heating but do you think maybe the hose's are old and are sucking in ? thanks
Old Jul 31, 2003 | 04:40 PM
JBronco's Avatar
JBronco
engine temp ?
How hot is it outside? Is your AC on? 215 is a little high but not excessive. The thermostat should not even open until 190 if it is stock.
Higher than normal temps at highway speeds are usually due to a clogged radiator.
Old Jul 31, 2003 | 04:55 PM
89broncobob
engine temp ?
yes it is with the ac on ,and i live in south florida. other then that the truck runs at normal temp even on long trips around town ..?
Old Aug 1, 2003 | 10:50 AM
JBronco's Avatar
JBronco
engine temp ?
I grew up in Miami, and it gets very hot there. 215 is probably ok since it is not overheating. Running the AC causes the truck to run hotter, due the the increased load of the compressor. But if it runs hot at highway sppeds and cools down when you stop, it could be a clogged radiator.
I would have the radiator professionally backflushed and refilled, and they will also be able to tell you at that time if it is clogged.
Redfridge
Nov 15, 2016 07:46 AM
navigatorstang
29
Jan 11, 2016 06:17 PM
BGF100
Nov 13, 2015 08:14 PM
jpa
2004 - 2008 F150
Oct 3, 2009 09:43 AM
Red Ford Truck
Ontario Chapter
Sep 2, 2009 06:30 PM
