2006 STARTING PROBLEM
Old Jul 22, 2015 | 02:28 PM
DAWGONE's Avatar
DAWGONE
LONG STORY SHORT, BOUGHT A 2006 ,TOOK IT TO THE BEST DIESEL MECHANIC I KNOW HAD IT BULLET PROOFED AND EGR DELETE AND SCT PROGRAMMER , DROVE IT HOME 200 MILES ON 65 HORSEPOWER. GOT HOME DECIDED TO CHANGE THE SETTINGS , BOOM NOTHING. BEEN ON THE PHONE WITH SCT FOR THREE HOURS FINALLY TOLD ME IT WAS A TRUCK PROBLEM AND NOT THEIR PROGRAMMER. TURN THE SWITCH NOTHING,NADA ,CHECKED BATTERIES, CABLES, GETTIN READY TO PUSH IT OFF IN THE WOODS. CAN ANYONE HELP?????
Old Jul 22, 2015 | 03:29 PM
betrayz's Avatar
betrayz
Does it have the factory programmed saved to revert it back and see if the tune is the problem?
Does anything work with the key on or off like brake lights, head lights, fuel pump noise?
Old Jul 23, 2015 | 07:10 PM
DAWGONE's Avatar
DAWGONE
lights and most of the gauges are working, had a mechanic buddy come by and we jumped it across the fuse box so it will run just will not crank, yes i reloaded factory saved program. but there is definitely some screw up no a/c, no temp readings, very sluggish, guess we'll go to the stealership and pay out the nose to get a reboot. then i will retry the sctx4 again. seems the installing mechanic did not check for updates before he loaded the sctx4.
Old Jul 23, 2015 | 07:41 PM
Per4mance's Avatar
Per4mance
I had a similar problem with my Livewire,I disconnected the batteries and turned on the headlights for 15 min and hooked it back up and it rebooted itself. Try it out and get back to us
Old Jul 25, 2015 | 09:00 AM
DAWGONE's Avatar
DAWGONE
o well
yea I did the battery disconnect, I re- charged batteries to full charge.i think now its a fault computer program or something
BrdNV82
2009 - 2014 F150
May 24, 2015 05:28 PM
DUB85
Nov 20, 2013 04:42 PM
greenheads
Oct 15, 2013 07:33 PM
Hatter
2004 - 2008 F150
Mar 9, 2011 10:17 PM
Mike-11
Jan 17, 2010 09:08 AM
