Rust Assessment, Need Input, What To Do?
To me it looks like the rust is mainly on the lip of the gutter. This area was repaired by the PO at some time and you can see what I believe might be bondo. You can also see how close the aluminum trim molding is down on the gutter itself. I think perhaps I should remove the aluminum trim better access the damage.. Once the trim is off then perhaps I should go all the way around the gutter and clean, re-caulk, reseal, and paint where necessary.
I tried to take pics from under and above..
These first two pics are of a seam joint on the rear of the van and not the repair.
<a href="http://s472.photobucket.com/user/Annaleigh_123/media/WP_20150719_20_22_07_Pro.jpg.html" target="_blank"><img src="http://i472.photobucket.com/albums/rr88/Annaleigh_123/WP_20150719_20_22_07_Pro.jpg" border="0" alt=" photo WP_20150719_20_22_07_Pro.jpg"/></a>
you can see the caulking going bad here
<a href="http://s472.photobucket.com/user/Annaleigh_123/media/WP_20150719_20_22_17_Pro.jpg.html" target="_blank"><img src="http://i472.photobucket.com/albums/rr88/Annaleigh_123/WP_20150719_20_22_17_Pro.jpg" border="0" alt=" photo WP_20150719_20_22_17_Pro.jpg"/></a>
This pic is of the PO repaired area
<a href="http://s472.photobucket.com/user/Annaleigh_123/media/WP_20150719_20_19_56_Pro.jpg.html" target="_blank"><img src="http://i472.photobucket.com/albums/rr88/Annaleigh_123/WP_20150719_20_19_56_Pro.jpg" border="0" alt=" photo WP_20150719_20_19_56_Pro.jpg"/></a>
This is the front of the repair where it joins to the original gutter just in back of the drivers door.
<a href="http://s472.photobucket.com/user/Annaleigh_123/media/WP_20150719_20_20_45_Pro.jpg.html" target="_blank"><img src="http://i472.photobucket.com/albums/rr88/Annaleigh_123/WP_20150719_20_20_45_Pro.jpg" border="0" alt=" photo WP_20150719_20_20_45_Pro.jpg"/></a>
This is top view middle way of the repair.
<a href="http://s472.photobucket.com/user/Annaleigh_123/media/WP_20150719_20_20_49_Pro.jpg.html" target="_blank"><img src="http://i472.photobucket.com/albums/rr88/Annaleigh_123/WP_20150719_20_20_49_Pro.jpg" border="0" alt=" photo WP_20150719_20_20_49_Pro.jpg"/></a>
This is the underside view.
<a href="http://s472.photobucket.com/user/Annaleigh_123/media/WP_20150719_20_19_40_Pro.jpg.html" target="_blank"><img src="http://i472.photobucket.com/albums/rr88/Annaleigh_123/WP_20150719_20_19_40_Pro.jpg" border="0" alt=" photo WP_20150719_20_19_40_Pro.jpg"/></a>
Thanks in advance
I think mine is contained in the one area..
Perhaps my headliner might be easy to get out and I could take a peek from inside
came across this. Guy has a lot of specialty tools, but still an interesting look a rain gutter repair.
https://www.ford-trucks.com/forums/1...st-repair.html
