Some Progress
Old Sep 24, 2015 | 10:20 PM
GeeeMCeee's Avatar
GeeeMCeee
Originally Posted by hotfalcoon
Your steering box looks like a '78-'79.
Is that correct?
Not sure it was on the truck when I got it, seems to be set up well, but obviously not original. I'll see if those guys recognize it.
Old Sep 25, 2015 | 01:27 PM
hotfalcoon's Avatar
hotfalcoon
The frame was probably shortened at some point.
If so could you post some pics of that area?
Thanks
Old Oct 23, 2015 | 06:21 PM
hotfalcoon's Avatar
hotfalcoon
Just wondering if you've had a chance to look at the frame. I have a high boy frame and may put my body on it.
Old Oct 25, 2015 | 04:37 PM
GeeeMCeee's Avatar
GeeeMCeee
Falcoon, the frame was shortened, it used to be a long bed, rear spring perches are now bolted on and not very carefully. Are you referring to the front or back of the truck? Front seems untouched. When I first got it the front axle was too far fwd.
I was able to center a little better by turning the front springs end for end, there is a 1-1/2" difference, it still could use a bit more, but is going to be good. Not sure why the PO didn't move the body farther forward, the firewall was almost touching the 460, but that could have been moved forward also. The PO also had installed his own lift kit, which I want to rework this winter.
Old Oct 25, 2015 | 08:03 PM
GeeeMCeee's Avatar
GeeeMCeee
On the road again
for a couple of minutes.
Old Oct 25, 2015 | 08:15 PM
GeeeMCeee's Avatar
GeeeMCeee
A couple photos
Old Oct 26, 2015 | 10:40 AM
hotfalcoon's Avatar
hotfalcoon
Referring to the rear.
Thought maybe they cut out a piece from the middle and welded it back together.
Sounds like they cut off the back and relocated the spring perches.
Hofdog
20
Jul 29, 2020 09:05 AM
BiGGreen350
16
Jun 25, 2015 08:57 PM
Kirbys73F100
32
Mar 29, 2011 10:49 PM
L. Ward
Dec 19, 2010 04:40 PM
boss460
Feb 6, 2006 05:17 PM
