91 Sas 460
Old Feb 5, 2006 | 07:31 PM
boss460's Avatar
boss460
91 Sas 460
well its done my 91 F150 its got the SAS, 205t-case twin stick, 4spd out of a 78. 460 out of a 89 f 150 converted to carb bored 30 4in springs in front ant blocks in the rear with 355 gears. it drives nice and pulls like a mule sucks gas like a jet plane.
Old Feb 5, 2006 | 11:53 PM
boss460's Avatar
boss460
if u look at my profile here on this forum you can see what i started of with
Old Feb 5, 2006 | 11:54 PM
boss460's Avatar
boss460
Old Feb 6, 2006 | 09:25 AM
Flareside94's Avatar
Flareside94
How much did you cut the crossmember with that 4" lift. You need to worry about smacking your differential in at that height unless you trimmed alot back.
Old Feb 6, 2006 | 05:17 PM
Snatch Block's Avatar
Snatch Block
Is that the FI lower intake you used? Or did you swap the heads?
