My loaded flatbed...is it correct?
Old Jul 21, 2015 | 07:53 AM
Turbo Dog's Avatar
Turbo Dog
Of course...one more question. My friend welded the plates to his trailer frame. Mine has square holes in it for two carriage bolts. I need to move it back and forth a bit depending on how the WD hitch is set up. After this run with the truck the trailer will see full time duty with a 1000 gal water tank attached. Is it safe to just have the pinch bolts holding those plates to the trailer frame?
Old Jul 21, 2015 | 08:57 AM
Ferguson65's Avatar
Ferguson65
Not quite sure I'm following...............are you talking about the WDH snap brackets on the trailer tongue? If so I ran mine for years with just the single pinch bolt holding them on with no issues, as I'm sure most others have done. There's no real need to weld them on.
Old Jul 21, 2015 | 10:39 AM
RV_Tech's Avatar
RV_Tech
I do not see the need for welding. I would second Scott's comment above.
Steve
Old Jul 21, 2015 | 04:26 PM
Turbo Dog's Avatar
Turbo Dog
Yes, those "snap brackets" are what I was asking about. The bracket that the chains hook to...I didn't have a name for them. My friend welded his because the pinch bolt came loose a couple of times. Maybe a little blue locktite might help. It seems like it just causes the bracket to flex if I put much torque on the screws. How tight should they be?
All yall have been a great help to me, I'm new to towing any reasonable amount of weight.
Old Jul 22, 2015 | 08:03 PM
Ferguson65's Avatar
Ferguson65
You are correct they will flex or bend if you overtighten them. I'd just go snug, stop before the bracket deflects. Use a jam nut on the bolt and it should stay put. Mine always did.
Old Jul 23, 2015 | 08:36 AM
Turbo Dog's Avatar
Turbo Dog
Thanks, I hadn't thought about adding a jam nut...and of course I've already been over tightening them. I ordered the rear straps so I hope to be able to tie down the truck for a test run next week. If it will stop raining for a day I also want to put a new coat of oil based stain on the wood to help protect it.
RedRocketFx4
Apr 28, 2018 09:51 PM
ecm2
All Things Towing
Sep 7, 2017 04:32 PM
1L243
All Things Towing
27
Jul 4, 2017 05:32 PM
ExxWhy
All Things Towing
Feb 13, 2017 10:29 AM
j4henry
Oct 13, 2011 10:12 PM
