Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2002 Escape not turning over
Old Jul 13, 2015 | 06:55 PM
portageedemo's Avatar
portageedemo
I was having problems with my 02 Escape of misfire on cylinders. After doing a lot of checking, changing spark plugs, changing coils, ect, I decided that it could be the computer. So, I ordered one and put it in. When I turned on the key, all the gauges pegged and then came back to zero, but it acted like someone cut the power line to the starter. No click, no nothing. I checked fuses and they are fine. Even changed them around to make sure. Is there something that I have to do when you change the computer to get it to start? Had no problems with the starter prior, so it has to be something associated with the computer and changing it.
Thanks in advance.
Ken
Old Jul 13, 2015 | 09:04 PM
projectSHO89's Avatar
projectSHO89
You CANNOT simply swap out the computer, it will DISABLE the whole engine. You have to reprogram the security system at the same time. Dealer or well equipped locksmith job, maybe a high-end mechanic's shop can do it.
Old Jul 15, 2015 | 02:04 PM
portageedemo
Thanks. Figured it was something like that. Wish their was something in the installation instructions that mentioned that. Will load up on a trailer and take to the dealer.
Ken
Old Jul 15, 2015 | 03:32 PM
projectSHO89
Those instructions ARE in the factory service manual.
map054
6.4L Power Stroke Diesel
May 14, 2010 07:51 PM
pfd843
1997 - 2003 F150
Jul 31, 2006 08:05 PM
F-250-Ed
Electrical Systems/Wiring
Feb 28, 2006 06:32 PM
moritz1024
1978 - 1996 Big Bronco
Sep 14, 2004 04:19 PM
RTM
Dec 19, 2003 04:05 PM
