Spring Tower Question
Old Jul 13, 2015 | 04:09 AM
Crop Duster's Avatar
Crop Duster
Is there any difference in strength between the towers with the reinforcing rods welded to them and the newer ones. I am going to have to remove my towers because of corrosion between them and the frame and both of my parts trucks have the reinforcements welded on the towers where my project doesn't.
Old Jul 18, 2015 | 03:32 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What year and series is your truck, 2WD or 4WD?
Old Jul 19, 2015 | 03:50 AM
Crop Duster
Spring towers
It is a 1965 2WD. Both parts trucks are also 1965 2WD. My project uses the strap bolted to the top of the tower to retain the spring and both parts trucks have a strap on the axle that limits the travel.
Old Jul 19, 2015 | 10:59 AM
NumberDummy
Illustrated as 5A306 in pic.
C6TZ-5A306-C (replaced C5TZ-5A306-A) .. Front Spring & Shock Absorber Housing / Obsolete
1965/74 F100 2WD / 1975/79 F100/150 2WD / 1965/70 F250 2WD / 1971 F250 2WD before serial number M00,001.
1971 F250 2WD from serial number M00,001 with 6,200 & 6,900 lbs. GVWR's / 1972/79 F250 2WD Regular Cabs with 6,200 & 6,900 lbs. GVWR's (1973/79 F250's without 460's).
1973/79 F250 2WD's with 6,200 & 6,900 lbs. GVWR's have single piston caliper disc brakes.
Old Jul 19, 2015 | 02:06 PM
Crop Duster
Spring Tower
Thanks! I may look for a pair of the C6TZ towers. Since my parts trucks apparently have the C5TZ's. There must have been something weak about them or the factory wouldn't have went to the trouble of welding a reinforcement on them.
swoosh1958
Apr 29, 2017 07:59 PM
belshe92
Jun 2, 2016 11:51 PM
bkaul
May 16, 2015 05:15 PM
lapper52
Aug 11, 2009 12:46 PM
