Help ASAP!
Old Jul 11, 2015 | 07:27 PM
dvldog13's Avatar
dvldog13
It did turn over......so I need to contact SCT?
Old Jul 11, 2015 | 07:28 PM
Maxium4x4's Avatar
Maxium4x4
I have had plenty of no starts experimenting, but that was with my tuner, not truck to truck, so you may be very well right Bud. Thanks for the info. To the original poster, do you have anything? Headlights, fuel pump, dash gauges?
Old Jul 11, 2015 | 07:29 PM
Maxium4x4's Avatar
Maxium4x4
Ok, go with Buds advice and contact SCT or tow it to Ford.
Old Jul 11, 2015 | 07:32 PM
dvldog13's Avatar
dvldog13
All lights and gauges still work
Old Jul 11, 2015 | 08:08 PM
dvldog13's Avatar
dvldog13
Thanks everyone.......I appreciate the help......
Old Jul 11, 2015 | 08:22 PM
Maxium4x4's Avatar
Maxium4x4
Your Welcome and report back when the mystery is solved.
Old Jul 11, 2015 | 08:59 PM
dvldog13's Avatar
dvldog13
Got a emergency call in to SCT......waiting on the call back
Old Jul 12, 2015 | 10:12 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
If it turns over???? Do you get a CEL? IIRC, mine wouldn't even turn over... it was like the ignition was dead.
Old Jul 12, 2015 | 11:11 AM
dvldog13's Avatar
dvldog13
No cel.....but with the y/b wire jumpered out it did turn over.....starting to wonder if the thing is in some sort of protect mode......tuner says stra. Is back to stock.........so it should run........
Old Jul 13, 2015 | 05:56 PM
dvldog13's Avatar
dvldog13
Ok .....got it towed up to ford dealer.......they reflashed the ECU and still nothing.......injectors buzz, gauges all roll........and no cel........
Old Jul 13, 2015 | 06:30 PM
dieselbogging's Avatar
dieselbogging
Double check all your fuses. Are you just using the tuner to check codes or a scan tool?
Old Jul 13, 2015 | 06:41 PM
Maxium4x4's Avatar
Maxium4x4
Tech should be able to tell you why it has a no start, it may have not even needed a flash. Any fuel in it?
solunamar
Nov 6, 2013 03:15 PM
powerstroke 6.0
Mar 19, 2007 12:18 PM
MobeyDick
Feb 12, 2006 06:41 PM
