Won't Start
Old Jul 10, 2015 | 10:57 PM
Jeff64F100CrewCab's Avatar
Jeff64F100CrewCab
Won't Start
Background. Bought the truck a few months ago, so don't have a long history on it. EFI v8 4X4.
Drove it from Nevada City CA to Belmont CA, about 100 miles early in the morning. Loaded up over 1000 pounds of various bits of steel (lowered the 3" lifted rear end to lower than level).
Drove home which is uphill on an over 100 degree F day.
I stopped for about 10 minutes and it wouldn't start. Suspecting heat soak to the starter (I've had that problem in at least a few cars) I got ride home and went back the next morning. I took a jump pack with me, and while it didn't start on the first try, it did with the second and drove it home.
Now it won't start at all with or withou the jump pack. I had attached a battery maintainer overnight just because I had one available.
It clicks and then nothing. Just like it had done after the long hot drive.
Ideas? Things to try, check, or investigate?
Jeff '87 F150 4X4
Old Jul 11, 2015 | 07:40 AM
subford's Avatar
subford
You say clicks and not chatter so I would replace the starter solenoid on the fender.
Could also be bad battery cables or connection of the cables at the battery or engine block (ground/NEG).
Old Jul 11, 2015 | 12:46 PM
daddylee100's Avatar
daddylee100
What he said ^
I went through this with my '92 a while back. Replaced the fender relay and it worked for a week. Replaced again and it worked for a day or 2. Replaced starter and same thing "click". Finally replaced positive cable from batt to starter and battery to relay (1 cable oreillys $50.00) and its been perfect ever since going on since september.
Old Jul 12, 2015 | 09:31 PM
Jeff64F100CrewCab
Well, I replaced the relay and cleaned up connections and ground connections and it made no difference. Took the starter out and went to Autozone where it tested bad. Replaced the starter all all seems good for now. Thanks for the guidance all.
Old Jul 13, 2015 | 07:28 AM
dixie460's Avatar
dixie460
Hope you got the lifetime warranty on that AutoZone starter. I went thru THREE of them in less than two months on my 460 before I finally got a good one! After that I more or less quit buying parts from AutoZone except for name brand stuff. NEVER house brand or their proprietary junk. Still have an AZ water pump on my truck (waiting for it to go kaboom) and front suspension bushing (falling apart already, need to replace with Energy Suspension bushings).
Just in case you do have trouble, bring a hammer and block of wood. When the junk starter gets stuck, use the wood and hammer to tap on it. That'll get it going again for a little while.
reckless121691
Dec 15, 2010 09:59 AM
dkaiser1963
Feb 17, 2008 11:12 PM
thought_criminal
Oct 20, 2003 07:25 PM
heybrent
1978 - 1996 Big Bronco
Sep 4, 2003 10:33 PM
BEAVER
Jan 20, 2002 02:44 PM
