Start has me puzzled, help!
Old Feb 17, 2008 | 07:52 PM
dkaiser1963's Avatar
dkaiser1963
Hello All,
I went to start my '93 F-350 today, had it plugged in and it turned over briefly, then the starter just clicks.
Thought that maybe batteries were low so charged them, even though they weren't.
So, then I figured the starter must have given up, so I took it off.
Then I tested it with jumper cables and it works fine!
So I'm thinking some wires or solenoid must be bad, they seem ok, so I just hook up the electrical and don't bolt it in and it works.
The only time it just clicks is when it is bolted in, I'm stumped, please help!!!
D
Old Feb 17, 2008 | 09:40 PM
brown 4x4's Avatar
brown 4x4
Check for power with the key in "start" at the small wire on the starter. You're probably hearing the relay on the inner fender clicking. They can go bad and still click.
Old Feb 17, 2008 | 11:12 PM
e1p1's Avatar
e1p1
Before you get too exotic or expensive with the parts, make sure you've covered the basics....battery terminals and cables. I had a Cherokee have similar issues and after ai replaced the starter and the battery it turned out to be corrosion in the positive battery cable, underneath the plastic insulation. Soaked up so much current there wasn't enough left to do the job.
The cable looked and felt fine, but I peeled back some of the covering plastic and it was a green mess. I replaced the cable and everything spun like crazy and it started in a split second. Similar thing with my F-150 a couple years back too.
Maybe try a jump from the battery to the starter with the starter mounted?
