Help
Old Jul 10, 2015 | 01:44 PM
Pamela Michelle's Avatar
Pamela Michelle
Help
How much transmission fluid do I put in a 1999 ford f350 7.3 diesel with a torque converter.
Old Jul 10, 2015 | 02:01 PM
SpringerPop's Avatar
SpringerPop
That's hard to answer until we know what you've done to it.
Did you drain it including the torque converter, for service?
Did you just drain the pan, also for service?
It this the initial refill after a complete rebuild?
Are you just topping it off?
Pop
Old Jul 10, 2015 | 03:01 PM
Thomas White's Avatar
Thomas White
If it's dry, or you drained the torque converter as well, 15 - 17 is a good starting point. Bring it to temperature and adjust the level.
Pan only, start with 5 Qts. Bring it to temperature and adjust the level
maytea
13
Sep 26, 2015 02:09 PM
makthenif
Mar 8, 2011 04:07 PM
96f150
1997 - 2003 F150
Apr 17, 2009 07:18 AM
rmilchman
May 17, 2006 08:56 AM
csherman4383
Aug 9, 2005 03:27 PM
