Ignition problems
Old Jul 11, 2015 | 05:04 PM
Dieselamour's Avatar
Dieselamour
Originally Posted by loganmick
Where is the switch?
The switch is located about half way down the column and you access it by removing some of the dash cover and two nuts. When you remove the nuts from the column the column will drop several inches and you can reach up around the brake area and R&R the switch.
Old Jul 11, 2015 | 05:09 PM
Dieselamour
Your best bet is to drop the column, and to remove the switch. Then use a small screwdriver, in place of the metal rod you removed, to work the ignition switch. Test it about a dozen times. If, within 12 times it cranked every time, it is most likely that your actuator (ignition switch actuator) is bad, or your switch was out of adjustment -possible but not likely.
Luko
13
Nov 24, 2017 01:05 PM
RadioControlGuy85
Jan 18, 2016 08:10 AM
snowcrash47
Mar 13, 2012 11:29 AM
johnsteffy
Dec 31, 2010 12:09 PM
jrv
May 16, 2008 08:49 PM
