120V Outlet Pushed into Console
Take it out and take it apart. You can easily bend the tangs so they will hold a plug again. Did it on mine and need to do it again. The plug pulls straight out without disassembling anything.
I removed mine with a couple of screwdrivers gently (I skipped the gently part) prying it out. It may be better to access the back part if you can. To reinstall the plug you just push it in and it has a friction fit. When I removed mine I broke one of the friction fit tangs. Still works ok but doesn't fit real tight anymore. If you can access the rear of the plug you may be able to pinch the tangs in better making removal easier.
Steve, I did successfully repair my plug. I did take the rear top and end of the console off. I do not have much vision in my right eye (recovering from a detached retina) and it was much easier for me to see what I was doing by taking end piece out in sunlight on the picnic table.
I got the receptacle out with no problem by squeezing the tangs on one side and then the other side. It took me a little bit to figure out how to take the receptacle apart. But I did so successfully and squeezed the tangs together. It won't last; that is one cheaply made Chinese receptacle. But it will work for a while.
Again, thank you for your guidance. Another successful project!
Thanks for the link Larry. Very good instructions on how to access the inside of the console. As it turns out my tangs are so bad that there is zero friction when inserting a plug. I have the plug out but am not doing as good as a job as Carl figuring out how to take the receptacle apart. Any hints for me Carl or Steve? Or anyone else that has successfully taken the receptacle apart.
Thanks,
Al
Thanks,
Al
Thanks,
Al
Thanks,
Al
reamer
Escape & Escape Hybrid
02-22-2017 09:01 AM
EmergencyManagement
1997-2006 Expedition & Navigator
03-10-2008 10:37 PM
