Voltage reg problems
Old Jul 9, 2015 | 12:36 PM
swmr1's Avatar
swmr1
I have a 1983 f150 4.9l. I have been having charging issues with my truck and while replacing my voltage regulator today this fell off the wire. it get screwed into one of the bolts that hold the regulator to the fender?
What is this? What does it do? How can i fix it?
Old Jul 9, 2015 | 12:39 PM
Franklin2's Avatar
Franklin2
It's just to keep the buzzing noise out of the radio. You can leave it off for now. It should bolt under one of the regulator mounting bolts or any good ground, and the wire will hook to the yellow "A" terminal on the regulator.
Old Jul 9, 2015 | 12:45 PM
swmr1's Avatar
swmr1
could this not being there cause my charging issue?
Old Jul 9, 2015 | 12:47 PM
Franklin2's Avatar
Franklin2
Will not affect anything but the radio.
Old Jul 9, 2015 | 01:05 PM
swmr1's Avatar
swmr1
Then what could be my charging issue? my alternator and my regulator work. and i can use a jumper at my regulator and get it to charge
Old Jul 9, 2015 | 04:51 PM
Franklin2's Avatar
Franklin2
Do you have gauges in the dash or idiot lights?
Old Jul 9, 2015 | 06:16 PM
ctubutis's Avatar
ctubutis
You tell us you have charging issues but not a clue as to what the actual issues are... is it not charging? Sometimes charging? Overcharging? What are the voltages at the battery with the engine running at idle, at 2,000 RPM, and not running?
chadjeppig
Mar 15, 2014 05:21 AM
daltonhawk
Electrical Systems/Wiring
Dec 21, 2011 01:08 AM
grams72
Oct 1, 2010 10:48 AM
qman
Sep 13, 2007 02:13 PM
dieself250
Jun 7, 2005 10:51 PM
