Tail light wiring question?
Old Jul 8, 2015 | 05:54 PM
52' fordnut's Avatar
52' fordnut
I have a couple of wiring questions on my tail lights for my 52 Ford F1.
1- Has anyone found any connectors to use with these type pins that are on the end of my tail light harness?
2-I have two wires, I'm assuming the black wire is the ground, while the green wire is the hot?
Thank you!
Jon Preston
Old Jul 8, 2015 | 06:49 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
They are bullet connectors and any good electrical supply place will have them. Good (not chain) auto parts stores should have them or can get them. They come in two sizes. the bullet side not the wire side.
Old Jul 8, 2015 | 06:53 PM
ALBUQ F-1's Avatar
ALBUQ F-1
NAPA has blister packs of them on a rotating display at my local store. Dave is correct, mike the bullet before you go, so you get the right size.
If your taillights are stop/tail lights, one wire is stop/turn, the other is parking light. Then grounded thru the bed connection (not very reliable, so I added a grounding wire).
Old Jul 8, 2015 | 07:36 PM
FortyNiner's Avatar
FortyNiner
What type of bulbs - single or dual filament?
Old Jul 8, 2015 | 07:47 PM
52' fordnut
I went with the dual filament bulbs. They have the turn signal function as well as braking and park lights.
Old Jul 8, 2015 | 08:09 PM
FortyNiner's Avatar
FortyNiner
Then Ross is spot on (keeping his streak alive). Green - and brighter filament - for the brakes.
paintescape
Jul 7, 2019 07:13 AM
Mason_72_F100
Jun 18, 2019 08:03 AM
sledr900
Oct 29, 2017 11:50 AM
Steven Gatley Sr
Electrical Systems/Wiring
Nov 7, 2014 08:10 PM
ldouble619
Feb 14, 2014 06:41 PM
