keyless entry remote doesn't work
Old Jul 8, 2015 | 02:36 PM
idaho potato's Avatar
idaho potato
Hello, hopefully someone can help out there. I have a 2010 Explorer and a few days ago the remote stopped working all of the sudden. It will not lock, unlock, open the rear glass or panic button. However the power locks inside the vehicle still work if I use the door button. I am not aware of anything else that is not working. The first thing I did was change the battery in the remote and it still will not work. I tested the remote at Auto Zone and it showed that it was working (or at least it was transmitting a frequency). I then checked fuses in the vehicle and could not find a bad fuse. I then tried to reprogram the remote to the vehicle and the process all seemed to work fine but when I tired the remote after exiting the programming mode it still will not work. I retried it several times to be sure I was doing it right and still nothing. During the reprogramming when I push a button on the remote after the 8 turns of the key the doors locked and unlocked signalling that the remote was programmed, but as I said after exiting the vehicle still does not respond to the remote.
Any Ideas???
thanks in advance
Old Jul 8, 2015 | 05:21 PM
shorod's Avatar
shorod
Do you have a second remote you can try? If so, does it work?
-Rod
Old Jul 8, 2015 | 05:33 PM
idaho potato
No I do not have a 2nd remote.
smashclash
1997 - 2003 F150
Apr 14, 2016 06:30 AM
Miller
1997 - 2003 F150
Apr 17, 2004 09:33 AM
4x4_EB_Explorer
Feb 21, 2002 10:13 AM
Scoflo
Sep 6, 2001 03:24 PM
Steve
Sep 1, 1999 04:33 PM
