1990 dual tank with problems
i have read until my eyes are crossing, but haven't found anyone else posting symptoms i am having.
I have determined that I have a fuel delivery issue. It will run great for a while, (32psi at first) but then the fuel pressure starts falling until it finally dies. I checked this with a fuel pressure gauge as I duplicated the symptom. As it was fading out last night I got under it so I could listen to high pressure pump and it was making strange noises as pressure was dropping and the engine died out so I thought "a-ha!" Replace high pressure pump and the fuel filter, started it up, 32psi, and 20-30 minutes later pressure starts falling and she dies out. The high pressure pump still running and sounding better than the old one did until it shuts off because engine isn't running. This was all using front tank tonight. I get the wife to help with key on and off and i can hear the front in tank pump run and the rear tank does not run when switched. I am thinking that the rear pump went out some time ago and the front tank is now going weak and not supplying enough to the high pressure pump but I dont know what the in-tank pump pressure should be. Can it be checked at the fuel rail if I unplug the high pressure pump?
I would sure appreciate any insights
Run a hose from a gas can to the pump and see if the symptom persists...that would rule out the clogged pick up...
SIDE NOTE: WITH MY GAUGE ON THE FUEL RAIL, I COULDN'T GET A PRESSURE READING AT ALL FROM THE TANK PUMP ALONE , NEW OR OLD.
