What's largest tires we can run on stock suspension?
Having issues finding exact numbers, need to decide quickly if I'm going to put a 2.5" level kit on my front. If I can put a 34" wheel/tire on with no rubbing, I'll probably not lift. Don't need to go any higher than that.... for now.
I don't have the snow plow package.
I would go with aftermarket 18x9 wheels. What's the largest tire I could fit without any issues?
My current OEM 17" wheels/tires measure just at 31" and look ridiculous!
Thanks!
Thanks!
If you're at stock height, I wouldn't go more than ~35" in tire diameter, or you risk tire rub when you're turning.
The stock 275/70/18 that Ford puts on a lot of the trucks is 33.2" in diameter.
Unfortunately, there aren't many bigger 18" tire sizes in a Load Range E
A 295/70/18 has a diameter of 34.3"
A 305/70/18 has a diameter of 34.8"
on
1 Post
