injectors?
Old Jul 30, 2003 | 08:04 PM
gotgrouper?'s Avatar
gotgrouper?
injectors?
can i put 24# injectors in a '79 302 w/ no other mods right now?
thanx, mitch
Old Jul 30, 2003 | 09:47 PM
fordeverpower's Avatar
fordeverpower
injectors?
what kind of setup are you running on a 79 302?
Old Jul 31, 2003 | 08:30 PM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
injectors?
i wouldn't even use 19# injectors on a stock non roller 302
Old Jul 31, 2003 | 08:50 PM
90f150moneypit's Avatar
90f150moneypit
injectors?
In my '90 5.0 19# came stock but these are good for a lot of power.
Unless your planning on a very healthy cam and heads you don't need the 24#, it will just run too rich or you'll have to lean it way out with an adjustable FPR.
Old Aug 12, 2003 | 11:16 PM
pinellas50's Avatar
pinellas50
injectors?
The answer is no. At least not without the thing running like a pig. You need to be more specific. Is the system factory ford and if so what type? If its speed density it's not an option. If it's a mass air system you will need to get a different mass air sensor that is calibrated to work with the 24's.
Fldiesel73
Nov 8, 2016 07:37 PM
tjc transport
May 15, 2015 08:24 AM
tjustice
Apr 21, 2015 05:44 AM
GBURKS
Nov 21, 2010 11:31 PM
puffer
Dec 18, 2005 02:33 PM
