Lowering 92 Nite
Old Jul 6, 2015 | 11:10 PM
Fordhoard68's Avatar
Fordhoard68
Lowering 92 Nite
I have a 1992 Nite and I want to lower the front. Iv cut springs n my 68 but these are different. Thought about cutting the top then drilling and tapping a hole on the bracket to accommodate the spring as it won't have the pig tail type top. I really don't want to spend $200 on lowering springs. Anyone have any ideas ?? Thanks.
Old Jul 6, 2015 | 11:48 PM
Toplait's Avatar
Toplait
Do not attempt to cut them.. Unless you have some money saved up for some springs...Cause you will most likely be buying new springs afterwards. Swap in a 460 big block that will lower it down
1987-1996 F150 Pickup: Crown Suspension Lowering Kits Lift Kits Airride Leveling Kits
Old Jul 7, 2015 | 09:47 AM
Fordhoard68
I have an extra set of springs on a parts truck.
Old Jul 10, 2015 | 08:27 AM
MtTheJeffro's Avatar
MtTheJeffro
I researched this for my own 92 Nite I had a few years back. Because of the I beam suspension setup, you're best bet is to buy a proper kit with the drop I beams for the front. No quality easy way to lower the front of these trucks unfortunately.
Old Jul 10, 2015 | 09:17 PM
Briansshop's Avatar
Briansshop
You can drop the front with springs up to 3" and still get the camber in spec.
Old Jul 11, 2015 | 01:10 AM
Low 150's Avatar
Low 150
New user to this site. I used a DJM 3/5 kit. New I-beams drop front end 3" and flip kit on rear. Sits level after everything settles in.
Old Jul 11, 2015 | 11:07 AM
Diesel_Brad's Avatar
Diesel_Brad
^^^ what he said.
I lowered my Lightning IIRC 1.5" below stock ride height with just springs and it is alignable
Old Jul 28, 2015 | 10:08 PM
Fordhoard68
Thanks guys! I did cut a pair of springs. But I need to heat the top and turn it in a bit so it can latched onto the bracket.
MikePacey
41
Sep 28, 2015 02:48 PM
pdrhodes1
May 8, 2009 01:04 PM
Trav-Man
Jan 11, 2009 11:42 PM
ken selvy
Mar 17, 2007 06:37 PM
73Custom
Apr 11, 2002 02:26 PM
