GLOW PLUG RELAY PROBLEMS
Old Jul 7, 2015 | 08:22 PM
mahoney's Avatar
mahoney
Originally Posted by mahoney
orange wire which should be the rear small wire, should be a ground from pcm when key is on, need pcm ground to operate relay, hope this helps
Take rear small wire off of relay and supply a ground to relay you will hear relay click and relay will send power to larger wire. If this works then either yor wire from pcm is open or the driver in pcm burnt. Hope this helps you.
Old Jul 8, 2015 | 06:33 AM
kbarbee95's Avatar
kbarbee95
Look for a chaffed wire on the driver side valve cover the little square box with all the wires. I dont know if the pcm wire runs through there but thise wires have been knows to run and shirt eachother out. Just a possibility
Old Jul 8, 2015 | 10:36 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Originally Posted by Thomas White
I would be cautious until you determine if in fact it is wired correctly. Sending 12VDC to the PCM will cost you!
Here is a wiring diagram I just made to help.
Reps for the simplified wiring diagram Tom, very useful! I'm chucking that into the Folder of Useful Images.
Old Apr 3, 2018 | 12:18 AM
Sera Warner's Avatar
Sera Warner
Having trouble with glow plug
so I have a 2001 Ford F-350 super duty 7.3 diesal and I believe I have a problem with my glow plug relay cause when I replaced it after I did I turned on the key and notice there was not a WTS light on like there always has been. But today Before I replace the glow plug the truck had a hard time starting so I had to use either to get it started so thought it was the glow plug relay so I replace that then try to start there is no WTS light on and it will crank but no start even if I use either. So I take a test light and test it arch the relay the WTS light comes on and still have to use either to start it and the truck starts with only the relay arch the whole time. Then when we remove the arch the whole truck shuts off what is going on with my truck
Old Apr 3, 2018 | 07:52 AM
Colorado350's Avatar
Colorado350
Very confusing the way this is written. QUIT using ether! No WTS light is typically a blown fuse #30 under dash. Do you still have fuel bowl heater plugged in? That's typically what blow the fuse. What relay are you referring to, GPR? Below is a video to show you the proper way to test the GPR. If GPR is bad, then plug it in until you can get it replaced. I personally use the Stancor relay and it works incredibly well.
Old Apr 3, 2018 | 07:56 AM
Walleye Hunter's Avatar
Walleye Hunter
Do you have the relay wired in correctly? There is a nice diagram posted above to help you with that.
Old Apr 3, 2018 | 08:04 AM
Wes444's Avatar
Wes444
First step would be to start a new thread, second would be to research how to install a GPR, 3rd step is to replace the pistons with holes in them from the ether
Old Apr 3, 2018 | 11:51 AM
beef tits's Avatar
beef tits
My new Alliant GPR was buzzing after a month of minimal use. I switched to the bigger Stancor model. Good reviews on that and the install was pretty simple.
Old Dec 29, 2020 | 01:42 PM
Beatbox82's Avatar
Beatbox82
Originally Posted by Meg719
that is the big wire that comes off the the left side it you are looking at it from the front???
Yes that ALWAYS has 12.2V and when key is on it has 12.2V and the 2 smaller posts have 12.2V as well
The other larger post to the right has nothing EVER, even with a new GPR
Hi Meg. i know its been 5 years since u had this problem but I have it now with same year and model truck. All 3 poles giving me 12volts except the larger pole to the right feeding the power to the glow plugs. Do you recall how u fixed it?
Thanks,
Joe
Old Dec 29, 2020 | 01:59 PM
AllaboutMPG's Avatar
AllaboutMPG
Joe,
Are you checking it with key on or key off? Engine warm or cold?
Old Dec 29, 2020 | 05:05 PM
Beatbox82's Avatar
Beatbox82
Originally Posted by AllaboutMPG
Joe,
engine cold
key off only the 12v from battery lights up with test light.
key on 12v from battery and both smaller poles light up and the larger pole going to glow plugs does nothing.
I wanted to confirm this. sorry for late response
Old Dec 29, 2020 | 07:27 PM
AllaboutMPG
Ok so far every thing is working as it should except the ground leg or the relay. Next take the small wire off the relay that goes to the PCM and use a jumper wire to apply a ground to that small post on the relay. See if the relay pulls in and what the voltage is on the glow plug wire.
If it woks then the problem is with the PCM or the wire to it. If the wire is good then it is the PCM. This has happened quite a few times before and the guys who have had it happen usually just bypass the PCM with a switch in the cab to activate the glow plugs manually.
Edit: Just to be sure the truck is outside and cold, not in a heated garage? The PCM only activates the glow plugs below a certain temp. Can't remember what that is
Old Dec 30, 2020 | 05:07 AM
  #28
tjc transport's Avatar
tjc transport
i ain't rite
if i remember correctly it is around 100 degrees coolant temp. .
Old Dec 30, 2020 | 08:28 AM
  #29
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Glow plug cycle and time is determined by the EOT. I can retrieve more details from the Ford Service Manual if they are required, but I believe the image below indicates a good amount of information related to the operation of the GP's. Now, to figure out if the GPR is functioning properly or if there is a fault in the ground circuit.
Old Dec 31, 2020 | 01:53 PM
  #30
Beatbox82's Avatar
Beatbox82
Ok so I did what u said disconnected wire and ran a single negative jumper to small post and quickly tested larger pole and got power to glow plugs, truck started right up. Now we know problem is pcm or wire from pcm to gpr.
What next? or can it possibly be the eot sensor? if so where is it located
thank you
