weak 351w
Old Jul 30, 2003 | 07:32 PM
cjanddave's Avatar
cjanddave
weak 351w
I have a 89 f-250 351w fi C-6, 3 1/2 lift & 33's with 127,000 mi. It has 120 - 116lbs compression. I just got a 21' boat & trailer with a gross wt. of 5800lbs. The truck will pull it but going up hills 45-55 max. Whats the best and most low cost way to improve my hp, iam looking to keep this truck for 2 more years untill i can get a new f-250. Thanks
Old Jul 30, 2003 | 08:02 PM
fordeverpower's Avatar
fordeverpower
weak 351w
What is the rearend gear?
Old Jul 30, 2003 | 08:40 PM
cjanddave's Avatar
cjanddave
weak 351w
I'am not sure but the tag says v126c 55 10 28L29
Old Jul 30, 2003 | 10:10 PM
90f150moneypit's Avatar
90f150moneypit
weak 351w
Check your door sticker. There will be a 2 digit number. That will tell us what you have.
Mine says "axle 19" This translates to a 3.55 open rear.
Code Ratio Capacity Maker Type Yr
12 2.73 3800 FORD REG 1991
17 3.25 3300 FORD REG 1971
17 3.31 3800 FORD REG 1995
18 3.08 3800 FORD REG 1991
19 3.55 3800 FORD REG 1991
25 4.10. 5300 FORD REG 1991
29 3.55 5300 FORD REG 1991
35 4.10. 6250 FORD REG 1991
36 3.73 7400 DANA REG 1980
39 3.55 6250 FORD REG 1991
45 4.10. 7400 FORD REG 1991
49 3.55 7400 FORD REG 1991
65 4.10. 8250 FORD REG 1991
69 3.55 8250 FORD REG 1991
72 4.63 11000 DANA REG 1991
73 5.13 11000 DANA REG 1991
H5 4.10. 3800 FORD LIMITED SLIP 1991
H7 3.31 3800 FORD LIMITED SLIP 1995
H8 3.08 3800 FORD LIMITED SLIP 1991
H9 3.55 3800 FORD LIMITED SLIP 1991
B5 4.10. 5300 FORD LIMITED SLIP 1991
B9 3.55 5300 FORD LIMITED SLIP 1991
C5 4.10. 6250 FORD LIMITED SLIP 1991
C9 3.55 6250 FORD LIMITED SLIP 1987
D5 4.10. 7400 FORD LIMITED SLIP 1991
F5 4.10. 8250 FORD LIMITED SLIP 1991
W5 4.10 8250 FORD LIMITED SLIP 1995
Old Jul 30, 2003 | 11:30 PM
cjanddave's Avatar
cjanddave
weak 351w
It says axle 39
melohsparks
All Things Towing
Mar 9, 2017 12:47 AM
Louie-T
Sep 18, 2016 07:01 PM
General Geoff
15
Jul 28, 2016 11:21 AM
Cowboy Fleet
13
Nov 28, 2009 09:40 AM
nasty77f150
Apr 29, 2003 11:04 AM
