So I'm ready to put my new Edelbrock Performer RPM on my new motor and there are no holes in the intake gaskets for the exhaust crossover. ('71 351w 16 Bolt heads and gaskets). Should I cut them out so Exhaust can flow through the manifold or just leave the ports sealed up??
It depends,
If you are looking for power and willing to risk cold weather driveability issues then no. If you are looking for reliability and willing to take a performance hit then yes. But don't cut the gaskets yourself, the port that will need to be opened will need a steel lining so the exhaust gases won't burn the gasket material.
If you want it open, just get a different gasket set.
The plain RPM does. The RPM air gap does not. Why wouldn't the gasket burn without the hole verses burning if I made the hole? If I made the hole the same size as the ports why would anything burn?
In my experience any gasket that handles exhaust gases moving past it has metal installed. If you have the hole plugged then no exhaust can move past the gasket surface and damage it.
Does anyone know of any 69-74 351w big port intake gaskets that have holes for the exhaust crossover? I went to 2 of my local speed shops and knowone had them??
Evan,
I seem to remember my FE intake gaskets (62 ford) had a metal ring impressed into the gasket material only around the exhaust crossover port.
Since this was back in the 70's, I could be having another mental lapse. I never installed an intake on a 302/351 engine so I cannot say what the application details are on that motor.
I would suspect that if you buy (vs. customize) the gasket set with the exhaust port opening, it will be properly constructed - metal or not.
Port fuel injected motors don't have this problem but on a carb engine whether airplane or auto ice can build up inside the manifold choking the engine even on a 75-80F day. Carb Icing is the term. Serious problem on an airplane! That is why planes have carb heat and autos have manifold crossover. Block the passage and your engine, under the right atmospheric conditions, will choke itself and die untill it sits long enough for the engine heat to melt it. Then you crank up the engine and drive untill it freezes up again a few minutes later repeating the process until the weather changes or you open the hole in the gasket.
Best of luck to you,
Bill
I would think that just metalizing the exhaust crossover port would cause planarization problems with the intake ports???
